  1. hi,
    i just made my first own movie of a wedding. The problem ist that the 80 minutes clip is about 4 Gigabyte big, so that i would need more than 4 CD's to burn it.
    Is there any possibility to bring it down to smaller size without having a low-quality movie?
  2. may i ask how did you encode an 80 minute clip to 4GB large? wat settings/encoder did you use?
    Jul 2001
    Brazil
    Do you know what's .mpg files and how to convert your .avi to .mpg file? I think you dont't. I'm right??
    Please, feed back us.
  4. I know what mpeg is. The movie is in mpeg2 format, but i encoded it with the highest quality, possible with my Studio DV Software (DVD quality)??? Int he AVI format it would have been greater than 20 gig!
    <font size=-1>[ This Message was edited by: Philipp2001 on 2001-09-25 06:06:19 ]</font>
    Jul 2001
    Brazil
    I did want to be rude. Sorry, because I did not understand your question.
    I see no way. You must lose quality if you want to fit your .mpg file in 1 or 2 CDs.
    The TMPGenc VCD template (standart) looks great for me in my DVD Player Unit.
    Bye.
    Feb 2001
    Berlin, Germany
    Well, the filesize depends on the bitrate. If you used the HQ settings, it may be a bitrate of 5000-6000 kbps. I think you have to burn it as DVD or if you have a very fast DVD drive (standalone) you may be able to play it as XSVCD. If you want to have a smaller filesize you have to reencode it.
  7. First, unless you have a DVD-R you can't burn a DVD source, and most DVD players can't read 6000kbit/s, (max is normally ~2800kbit/s total).
    If you have an 80min video source, your best bet is to make 2 40min SVCDs (filling each disc). That's pretty close the the max bitrate of most players too.
  8. Hey Philips,
    if you use Studio DV to create MPEG-2 at DVD quality, then the 4GB file size is about right.
    Why do you want to burn this huge MPEG file on CD. Even after splitting to 5 or 6 CDs, no DVD player can play those.
    If you want to play your CD with your stand alone DVD player, then follow Vejita-sama's advise. It's going to work.
    BTW, do not use Studio DV to generate SVCD MPEG-2 file. The quality is horrible. Use TMPGEnc instead.
    _________________
    ktnwin - PATIENCE - PATIENCE - PATIENCE
    <font size=-1>[ This Message was edited by: ktnwin on 2001-09-25 17:20:34 ]</font>
