  1. I have a soundblaster live 5.1 sound card and on the back of it theres 3 audio outputs (front speakers, back speakers, and subwoofer). these are hooked up to my Creative subwoofer and then on the back of the subwoofer there are 5 audio output connections to connect to the 2 front, 2 back, and center speakers that come with the set.
    My question is how (if at all possible) can i hook up my sound card to my audio/video reciever (it has the 6 channel input).
    thanks
  2. Technicaly you can, and if i'm not mistaken, you can even use the SPDIF out function for better quality, that is if you have one on your Reciever, which i'm sure you do.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
