I have been debating abut putting a WD 120 GB external hard drive (7200rpm) on my comp to use exclusively for capturing video. Would I get any quality loss by doing this setup? I just wanted to make sure there would be enough speed for good quality video.
I have a 1.1g tbird process and 256 meg ram. When I capture I shut down everything else to keep resources free for capture.
Its a long story on why I want external instead of internal drive. So I wont bore you with that story
dp
This drive is slow.
I picked up an external firewire WD HD 120GB. I tried to backup some files to it. This drive took approx 8 hours to back up 6GB of stuff. My computer is 2GH P4, 1GB RAM. It was connected to a ADS Pyro Firewire card. I returned the HD.
Hope this helps -
I'm using a Western Digital 120 gig 7200 RPM External Firewire dedicated for video only. Works great. No problems.
Geronimo -
I am using a firewire connected drive for DV video and it works great! Yes it is slower than connecting to IDE. Different enclosures also have different speeds. Enclosures from Acom are faster than the ones with CompUSA on the label. Other than that, that's all I can tell you.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Something was wrong/defective somewhere in there.Originally Posted by LDM
It doesn't take me that long to transfer 6GB of mp3's to my crappy Archos Pukebox over USB 1.1 at a very slow rate. I think it only goes at 1.1 mbps. 6GB takes about 4 hours going to the Pukebox.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
I returned the WD drive and bought the 160GB Maxtor instead. The Maxtor is MUCH faster.Originally Posted by The village idiot
LDM...Looks like we may have/had the same drive. The Village guy is right. You had a defective drive.
Geronimo -
I do full system B/U on these type drives and up to 25GB does not even take close to 6hr on any of my machines all units around 2GHz and /\. You should be fine, I"ll have to time a lg B/U and see what they do take to run per gig.Originally Posted by LDM
<|;-{> Dd
Ilvlinux(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
Capturing VHS to External Hard Drive...
By the colonel in forum Capturing and VCRReplies: 10Last Post: 2nd Nov 2009, 20:34 -
external hard drive
By alintatoc in forum ComputerReplies: 20Last Post: 26th Sep 2009, 20:54 -
Problems putting a NEW Drive in an OLD External firewire box?
By phase52001 in forum DVD & Blu-ray WritersReplies: 3Last Post: 30th May 2009, 22:03 -
External Hard Drive > TV?
By jason in forum Newbie / General discussionsReplies: 36Last Post: 12th Mar 2008, 10:32 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
