  1. Hello,
    When i am capturing from my TV, using Virtual Dub, the capturing stops at 3 minutes, and my whole computer stops.
    I'm capturing at 480x576, using MJPEG-codec-compression at quality : 18.
    The AVI will be stored at a 20GB Harddisk, and i'm using this HD only for capturing, or converting DVD to MPG.
    During the capture, my CPU was between 30-60 % in use, and i had no frames dropped, but at 3 minutes....STOPS the PC.
    Anyone an idea what is going wrong ??
    My system :
    AMD Athlon 1400mhz, 256mb memory, 10GB,20GB HD. And capturing with an Pinnacle PC-TV-RAVE.
    Who can help me with my capture-problem with Virtual Dub ?
    Sep 2000
    Northern Virginia
    what video card do u have?
    Sep 2000
    Northern Virginia
    couple more questions:
    - do u have an ati for your video display card?
    - u don't, per chance, have the screen saver enabled, do u?
    Jan 2001
    Vancouver/Portland
    Some *rare* cases could be...
    1) Your TV Card gets overheated and locks up
    2) The hard drive you're capturing to had bad sectors
    3) If it's a new system, your motherboard might not be friendly with the TV Tuner (I had Asus A7A266 Mobo previously, it would lock up EVERY TIME I try to access my ATI TV Wonder or Pinnacle Studio PCTV Pro)
