I know this is a stupid question, but I have a cool MATRIX screensaver for my PC that I really like. Is there any way I could convert it to mpeg format to make it play continously on a vcd player?
93accordlx
I used the Matrix Screensaver as the background to a menu, at first I tried using a Screen Capture tool, but this didn't work well, what I ended up doing was using the S-Video out to a VCR tape, and then capturing that back onto my computer. It's kind of a pain in the ass but it worked and didn't take too long.
-Smd -
You might be able to use Camtasia http://www.techsmith.com/products/studio/default2.asp
It's worth a try....You can't fool me, I'm a moron! -
Yes, it can be done with Camtasia - here is a sample that I just did:
screensaver capture sample.zip (about 1.1MB)
it's not the greatest, but if you play around with the capture settings in Camtasia, you can probably get what you need.You can't fool me, I'm a moron!
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 04:00 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Screensaver for WMV,MPEG-2 clips and JPEG pics
By rch15 in forum Software PlayingReplies: 0Last Post: 18th Aug 2008, 01:14 -
Looking to convert scr files (screensaver slideshows) to avi or mpg format
By wiltonp in forum Video ConversionReplies: 1Last Post: 23rd Jun 2008, 18:28 -
ScreenSaver to AVI -MPEG
By arturjose in forum Video ConversionReplies: 3Last Post: 25th Oct 2007, 10:03
