  1. I had an .avi of a movie file. My adaptec program was locking up when i tried to burn it to a cd so i used disc juggler. I didn't check until I got home, but when i put it in my computer it says it is an audio cd. I can't really open it in anything to try to convert it. The file is called track1.cda. Did I just get the audio of the movie, or is there a way to get this back to either an mpeg or a .avi?
  2. Banned
    Jun 2001
    UK
    Sounds like its just put the audio on there. If you put it back in your writer, use EZCD to view info, might tell you what it is.
    Feb 2001
    51`N 5'W #linux & #vcdhelp @ DALnet
    Sounds like you burned an audio CD if all that it contains is a *.cda
    Back to the drawing board...
