I just decided to reinstall my Tv Wonder and attempt to caputre from my vcr in order to make some vcd's. Unfortunately, I can't capture with anything but MMC7. DVR & VirtualDub both give me "Cannot open capture device" errors. (DVR then gives a MSVCRT.DLL error and closes)
I've got all the proper DirectX 8 updates and the drivers for the TV Wonder from ATI and the card is on it's own IRQ from what I can tell. I'm running WindowsME on an ASUS p3v4x, p3 500, 383mb ram, ATIXpert2k video.
Also, I remember being able to capture directly into Premiere when I ran this card on the same system with Win98se.
Any helps would be great... this is kind of bugging me.
-Evan
The MMC7.1 has has WDM drivers which are not supported by virtualdub and mnay other programs. You can make virtualdub work by linking it to a VFW (Video fo rWinsows) wrapper for WDM. However, I have found that this is highly unsatisfactory and performs very badly under windows me.
You cna go back to your old state by using restore.
One silver lining is the MMC7.1 capture in mpeg and mpeg2 are of much higher quality than the old VFW solution. This allows you to brun VCD without further encoding.
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 10:16 -
Capture device
By ingeborgdot in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2011, 21:02 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
capture device for hd
By jjjamiem in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 15:30 -
Automatically open WinDV when DV device becomes active
By jabloomf1230 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 9th Jun 2007, 23:30
