  1. Hi
    I was wondering does anyone know if it is possible to make the mpeg-2 files smaller when using tmpeg? I am getting a rough file size of about 2.5gb per file after converting avi to mpeg-2 but i want to get the size down a little so i can fit more files onto the dvd, is it possible with tmpeg? changing the settings or anything?
    please help
    thanks.
  2. The isze of an mpeg file is dependant on 2 things. Bit rate and play length. There is not much you can do about the length of a movie (cut off opening and end credits perhaps). But you can change the bitrate and TmpGenc will let you choose almost any bitrate you want.
    You can calculate file size for a movie using a bitrate calculator if using CBR or VBR encodes
    However, if you are using TmpGenc's CQ mode, calculating filesize is more difficult, and changing filesize is done by changing the quality value, not the bitrate.
    Hope this helps.
  3. Thanks bugster that was a big help will be platying around with it in a bit. thanks alot dude.
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    check what kind of audio encoding is being done in TMPGenc - if you're using PCM audio instead of Mpeg layer II, you are adding a huge amount of data to your files.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
