I've done my due diligance and haven't found a good answer to my question...if it's even possible.
What I want to do is:
1) Remove (not just be able to stop during) warning on my backups
2) Totally remove alternate video streams while maintaining core menu
I use DVDShrink with which I can decrease size of alt video streams, but not eliminate (if you wanna keep menu).
I know how to config to be able to stop during required programming (or whatever they call it)...but how do I delete the junk before the menu/movie?
I suspect the answer (if there is one) will lie in IFOedit, but all the tuts I've read say if you mess with alt video you loose their menu...
Of course I've researched this for a while...
and five minutes after I post I find the answer to one question.
1) To remove the junk before movie see here
https://www.videohelp.com/forum/userguides/127933.php
still looking for help on #2 -
Not *exactly* what you are looking for, but you can definitely remove the links in a menu by using menuedit. Then if you reduce (in DVDShrink) the unwanted parts to still images you will have just about as small a disk as you could otherwise have (making them still images reduces them about 95%, so you're only losing about 5%).
"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Yeah, that's what I've been doin...
I'm just anal and it pisses me off not bein able to take that stuff off...
and its still several hundred megs even at 5%
Changing The Audio Of An AVI File "Language" {HELP COMPLICATED PROBLEM}
By Mr CMTS in forum EditingReplies: 1Last Post: 28th Nov 2011, 20:04 -
Capturing video from complicated website
By ger4llt in forum Video Streaming DownloadingReplies: 4Last Post: 28th May 2009, 22:33 -
Converting DVD to Mini DV - and it gets more complicated
By NSP in forum Video ConversionReplies: 13Last Post: 12th May 2009, 05:13 -
least complicated firewall software available?
By sdsumike619 in forum ComputerReplies: 20Last Post: 16th Apr 2009, 20:52 -
Connecting/setup VCR/DVD recorder complicated
By peeaytee in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 15:00
