I own Starship Troopers DVD and when I play it I hate having to take the DVD out of the player and turning it over in the middle of the film. So I am trying to convert to one DVDR.
I ripped both sides to my HDD, then took the main film VOB's from both rips and put them in one directory, renaming them in the process so that they were concurrent (VTS_01_1 to VTS_01_8). I then used IFOEdit to generate new IFO files etc. I then used DVD2one to compress the film to fit on one DVD.
I played the resultant on my PC using PowerDVD and it played OK with a small blip at the crossover point between the two halves. However, when I put it into my DVD player it went through to the join and then jumped back to the beginning and refused to play the second half of the film.
Can anybody give me some guidance as to where I went wrong, or advise on some other method that will do the job better?
Results 1 to 1 of 1
Artificial intelligence is no match for natural stupidity.
Joining two VOB sections from a DVD.
By jnetty99 in forum EditingReplies: 10Last Post: 14th Jul 2010, 18:36 -
Joining 2 files together to burn 1 DVD
By glorybaron in forum Newbie / General discussionsReplies: 2Last Post: 31st Aug 2008, 04:20 -
Joining DVD's with Menus?
By LCE in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2008, 00:16 -
joining 2 parts of a DVD?
By Itsmeshane in forum EditingReplies: 1Last Post: 23rd Oct 2007, 04:20 -
Re-joining a split DVD
By P.G.M in forum Authoring (DVD)Replies: 2Last Post: 21st Aug 2007, 08:54
