However the file im converting to VCD does not have this problem. How can I correct this?
Im using Tmpeg to convert the avi to vcd mpg. Thx
I did notice that the audio sync is present after I convert the avi to VCD mpg with Tmpegenc. What am I doing wrong?
Of what origin is your AVI? If it's not made by yourself, but downloaded, chances are pretty good that it suffers from all kinds of problems.
First attempt is to scan for and remove bad frames using VirtualDub.
Then extract the audio track in its original encoding (VDub, direct stream copy, save wav).
Now using the best suited tool for the task, decode this file (mp3, ac3, ogg...) to wav.
Use your wav as audio source and your cleaned AVI as video source when encoding.
This said, dl'ed AVIs are often too bad to be usable as source material for any type of VCD/SVCD/DVD. They may however often be enjoyed on your monitor or on a TV hooked up to your computer.
/Mats -
https://www.videohelp.com/divxtovcd.htm#audioOriginally Posted by pr-guy
Read: Audio-extracting stop when you get to Encoding:
Then goto: https://www.videohelp.com/tmpgenc.htm
and follow that tut.
This should clear up the audiosnyc problems.
decrepidloser
(yes it is a D and I can't spell
ASPI 4.60 | CDmage | DVD Decrypter | SmartRipper | Dvd2Avi | FitCD | GSpot | VDub | TMPGEnc + | CCE 2.5 | VFAPIConverter | DVD2SVCD | Photo2VCD Pro | WinDVD 4 | NimoCodec 5 b7 | VCDgear | ISOBuster | VCDEasy | Roxio 5 Basic -
mats how exactly do I remove the bad frames using virtualdub? is this an automatic feature?
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 03:32 -
WMM crashes everytime I import audio and I'm PISSED AS HELL
By Nintendo Fan in forum EditingReplies: 3Last Post: 23rd Oct 2008, 16:46 -
Wot the fark is this? I get this popup everytime my cursor touches a video
By jaxxboss in forum ComputerReplies: 6Last Post: 22nd Jun 2008, 10:28 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 08:13
