What does the CCE noise amd quality sliders do "visually" to the encoded movie, say when the sliders are moved from one extreme to the other.
And is there a way to batch encode avi files using standalone CCE2.5sp like in TMPG as I cannot find an option for it.
why not reading the manual?
This setting decides priority among image areas which the encoder
assigns to allocate the bit amount. 0 to 100 can be specfied. The
initial value is 25. Set the value in the window shown in Fig. 3.14,
which is displayed when the Quality priority button in the encoding
setting screen in Fig. 3.1 is pressed.
As the value becomes closer to 0, a higher bit amount is allocated
to complicated images areas. As the value becomes closer to 100, a
higher bit amount is allocated to flat image areas. When the value is close to 0, the mosquito noise at the edges (noise causing hazy part
along the edges, looking like flying mosquitoes) is less outstanding,
but the contouring noise (noise which looks like contour line patterns,
which appear in flat and wide areas, such as a dark background) is
more outstanding. The opposite occurs when the value is closer to
100.
3.3.16 Anti noise filter
This filter can be used to reduce noises in the original motion pictures.
The value you can specify is from 0 to 32. The bigger the value, the
stronger the filtering will be. If it’s too strong, frames will be like
progressive frame, so the movement of a encoded video will be jerky.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You do a batch encode, if you add more than one files to the encoder list.
Date Created - Batch Encode
By conandrum in forum Video ConversionReplies: 15Last Post: 14th Nov 2013, 15:57 -
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 07:10 -
Feature REQ:True batch encode
By tszpara in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Jan 2010, 04:30 -
Simple batch encode H.264
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2009, 12:32 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52
