  1. I'm having serious problems when capturing from VHS -> DVD (PAL) ;
    Captured video seems to be OK when looking on computer but wheb recorded to DVD, its 'shaky'!
    I've tried with several capturing progs and three different burning progs without success.
    This ONLY happens when burning VHS captured videos!
    Does anyone know how to do this properly!!!!
    All tips will help!!! (I'm going NUTS!)
    Short HW descr:
    - P4 2.5 GHz, 1 GB RAM 200 GB disk (100 free).
    - GForce4 128 MB with Video-In (analog)
    - Burned: Sony DRU-510a
    Capture tests done with: Ulead VideoStudio 7, VirtualDub and few more progs...
    Please help me....
    _|
    _| That's just
    _| Co0L!
    _|
  2. that's strange.....
    What settings are you using when you encode the video?
    Just what is this reality thing anyway?
  3. Could it be that the field order is off? Have you tried swapping the fields?
  4. Hi !
    I'm using capturing profiles for 'PAL - DVD (High Quality).
    (MPEG-2 video, 8000 kbit)
    I'm kinda newbie to this so all help counts!!
    Field order?? Should I do this wgen capturing??
    How / in what step??
    T.I.A.
    _|
    _| That's just
    _| Co0L!
    _|
  5. When you say it plays OK on the computer, are you playing the DVD you burned? Or are you playing the MPEG files on your hard drive?
    Also, have you tried just creating the title set and burning the DVD with another application?
