OK, so I have this .mpg file that I downloaded from Kazaa. If I just run it, it works perfectly in both Windows Media Player 9 and Divx Player. However, if I load it into VirtualDUB and simply play it, it doesn't matter what I do, what codecs I run with it, anything, it ALWAYS gradually loses sync. Consequently, I am unable to convert it to ANYTHING. Compressing it to .avi always loses sync, demuxing it always loses sync, even making a copy of the .mpg via TMPG (hence, I have the downloaded file, and another .mpg with the same exact properties and file size) results in loss of sync.
Has anyone ever came across anything like this? I ran Scan For Errors and, according to VirtualDUB, the file is perfect. No bad frames, no undecodable frames.
What would cause this? Is there ANY remedy for it?
System specs:
P4, 2.26ghz
ATI AIW Radeon 8500
512 RAM
80gb HDD (30gb free)
Windows XP
DIVX, XVID, Huffy video codecs
DIVX, Lame, Ogg, Windows Media audio codecs
Thanks.
Hey... I've seen something like this before...
Maybe you should try converting the video in TMPGEnc without changing the framerate.
If the video is 23,9fps, encode it again with the same 23,9fps... If you try to convert the original video to 29,97fps, it will really screw the synch.
Hope this helps... -
Argh, tried a bunch of different frame rates, above and below, and none of them helped (some even made it worse).
WMP 10 won't play CD's the audio is all choppy sounding, mp3's are fine..
By J Tinsby in forum Software PlayingReplies: 3Last Post: 14th Dec 2009, 06:32 -
VLC reports AVI broken, WMP plays it fine
By hemang in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2009, 01:15 -
mpg plays badly in divx dvd player
By ssalim in forum Video ConversionReplies: 25Last Post: 3rd Apr 2009, 11:39 -
x264 audio won't play in GB-PVR or WMP, works fine in MPC
By bigshotceo in forum Software PlayingReplies: 2Last Post: 15th Apr 2008, 10:55 -
VHS plays fine on TV, bad when captured...
By rachel.twu in forum Capturing and VCRReplies: 15Last Post: 10th Jun 2007, 00:38
