  1. I'm not really a newb when it comes to conversion, but I have never really had problems converting with TMPEGENC before...then again I've never worked with any xvid AVI files. Does anyone know what audio codec I need, I think it's some kind of MP3 thing.
    For some reason I can play Xvids on my system but when I encode them to mpeg I have no audio.
    I'm not really a newb but I've just never had this problem before.
    Any ideas?
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If you get Gspot from the Tools section then you can test your file for video and audio codecs and if you have them installed.
    You should extract a wav file from your source avi and use that as the audio input to TMPGEnc. Virtualdub can do that (for some avi types) or I like to use Goldwave which will process almost all avi audio types to wav.
