I am getting this error when i try to run the plus version. I installed it, and it worked great. Then I rebooted my comp, and when i tried to run this program again i started getting this error. I deleted the whole directory, ran the unistaller that chrissyboy wrote for this and installed the software again and it worked. Well that lasted a day or so, and Im gettin this error again. I tried unistalling and installing it again, but nothing this time. I am running windows XP, and i have all the latest updates. im stumped now...im wondering whats wrong here...i have enclosed a screen shot of the error im getting..if anyone can help i would really appreciate, because this is a kick ass tool and saves a lot of time....much props to chrissboy for this and all of you who reply to these posts.
Results 1 to 11 of 11
So i guess no one knows???? Damn this sucks.....i have a whole bunch of videos to burn and i dont want to go back to the old way.......
I'm working an a solution with antoher user.... Should have some news shortly.
scrtagt69: my "helper" has disappear & i would like to nail this ASAP. Can you drop me an email?
Much props to chrissyboy who wrote a quick fix for me on this error....thanks alot for your help man....
AnonymousGuest
Chris has spent all evening writing fixes for me to try and resolve a very similar same error for me. Not sorted it yet but boy what customer support this man gives.
Good on you Chris, its much appreciated as I really want to get this program up and running again, its so damn good and so fast I really can't be messing with all that performance I used to have to go through to write a DVD from an SVCD. -
Yeah I agree.....17 bucks with this kind of service....beats alot of these other software companies out there....if you guys dont have the + version its a must....we need support chrissyboy for all his hard work...
greetings fellow pc fanatics. i would just like to bother u guys for a quick solution to my problem! i am having the same common language runtime error. i tried to read some of the forum post to try to solve it myself but kept running into problems with .net frame. any help would be deeply appreciative!
THANX IN ADVANCE!
svcd2dvd%20troubles.txt -
THANX IN ADVANCE!
Have a look at https://forum.videohelp.com/topic324278.html#1672927
Runtime error
By alintatoc in forum ComputerReplies: 0Last Post: 20th Dec 2010, 15:19 -
On startup, keep getting a Common Language Runtime Debugging Services alert
By Carl III in forum ComputerReplies: 1Last Post: 18th May 2010, 17:04 -
Runtime error
By The Monarch in forum ComputerReplies: 4Last Post: 28th Feb 2010, 03:42 -
runtime error
By ram16 in forum Newbie / General discussionsReplies: 9Last Post: 20th Dec 2008, 23:04 -
Runtime Error
By clivedavies328 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Jul 2007, 15:33
