Ok I have no idea which topic this would be under because I do not know the problem. It seems like Ive been doing everything right. But after it gets done copying I slip into the DVD player it reads it as a VCD 2.0 or whatever and then when the movie starts to play its like the screen is jumping all over the place. I have no idea whats the problem...it seems like ive tryed everything. So if anyone could help me I would greatly appreciate it. Thanks.
tell us exactly how you made the VCD! what tools, settings...
Ok I used tmpgenc to convert the divx to mpg. I then used it again to cut the movie in half so I can fit it on the cd. I used Virtual Dub for the sound although the sound plays good its the video. I then used Nebo to copy the cd. Sorry I didnt have alot of information to give last time but that was because I was in a hurry. Please help. Thanks.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
VCD
By dodd22 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 17:01 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
VCD
By rocketboy in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 15:06 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
