    Feb 2003
    I use my ReplayTV to create MPEG-2 files from programming content and then I extract the files to burn to DVDs. Sometimes I prefer programming, esp 1 hour or less, to be VCDs, which of course, require MPEG-1 files. So I need a program to transcode the mpeg-2 down to mpeg-1.
    I was given a tip to use ffmpegx to do this task. However, using one engine it just stops with an error, and the other engine results in 3 files which seem to start at the same place and are not the complete programming. Help; thanks.
  2. 1/ Use VCD preset
    2/ If you get an error, post it here with the Terminal output
  3. NNisa
    Guest
    this is the error i got going from replay to svd
    Stream mapping:
    Stream #0.0 -> #0.0
    Press [q] to stop encoding
    **ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
    **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
    nnisa
  4. Please post the full terminal output, the input filename, and the results of "Info" on the input file.
