    Ca, Irvine, USE
    Does anybody know any devices that blocks macrovision from Vcr tapes?
  2. Yeah, I have one. It works great, except for the annoying little habit it has of also killing the part of the picture that my DC10+ needs to see in order for it to "latch onto" the picture for a capture. I also learned that feeding such damaged tape through this card to another vcr or card will restore the signal (not the macrovision). I have also learned by this that running a video signal through this card to another vcr will kill the macrovision all by itself!
    But, if you ain't got a card, and don't intend to make a VCD out of it later, I can sell you my protection remover.
  3. DAZZLE DVC 2 AND DVC1 BLOCK OUT MACRO ,FROM DVD AND VHS.
    Ca, Irvine, USE
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Check your private message box
  5. This will do what you want
    http://www.facetvideo.com/
    Also a box called SIMA sold at Bestbuy, and Compusa does the same thing.
