at the moment i have a mitsumi 4x speed writer and a phillilps dvd writer +r in my pc.
is it posssible to have 2 dvd writers in ur pc i.e 1 +r writer and 1-r writer .
can anyone for see any probs apart from 1 writer having to be master and 1 slave ...![]()
Should not be any problems with that. I have a DVD writer and a CD writer, i see no reason why 2 DVD writers should not work together.
i use 6 together (on firewire) , with a scsi drive feed system - using prassi special version for robotic duplicators ..
Not a problem at all. At one time I had 3 DVD burners in my PC (NEC1100A, TDK440N, and Pioneer 105 external through USB 2.0) and I had no problems whatsoever. Now i'm just running two of them, because I got rid of the NEC1100A
if u get instant cd/dvd 7.0 u can burn two disc at once provided they have same speed setting i.e. 4x, 2x, 1x on both of them
Sure my main computer has a Pioneer 105 4x DVD-R and an NEC 1100A DVD+R burner plus a LiteON 166s DVD-ROM drive.
I tried to use my Sony DRU-500AX with my Yamaha CRW-F1, but I had all kinds of software conflicts, so I sold the Yamaha....
JohnnyCNote
what kind of OS do u have
and what software are u using
i used to have conflicts when i had win 98
and also with the old easy cdc creator plat. 5 (direct cd was behind it)
but when i got more ram and got rid of both of them (i got easy cd 6 now not a problem)
i didn't have conflicts anymore
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 21:34 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 22:44 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 13:51 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 22:08
