Hi, I am trying to make a dvd out of 3 svcd's. So here's what i tried.
1. made the svcd's into .bin's
2.extracted the .mpg from the bin's with GNU vcdtools
3.joined the 3 .mpg's with mpgtxwrap (the joined .mpg plays fine in VCL)
4. Demuxed the joined .mpg, although it finishs demuxing, the terminal says "could not allocate Buffer of Size -1, Option Preserve Header now disabled!"
5. convert the mp2 to 48Hz
6. VCL frezzes when I try playing the m2v
7. If i try to mux the .m2v witht the mp2(48Hz) the terminal says "**ERROR: [mplex] File /Users/edmund/Desktop/joined.m2v unrecogniseable!
Any suggestions? the m2v is 1.97 GB, is it because the file is too large? whats going on?
Im also interested in this and posted similar a couple of weeks ago.
I think the problem is in step 3 (joining) or possibly step 2 (ripping)
does it have to do headers??
... sorry I'm no help but hopefully someone will be. -
Yes, mpgtx can't straighten out those bumps between joined parts. If you can boot into OS 9, you can use MPEG Append for free. If not, you'll have to pay $49 after the trial period.
http://homepage.mac.com/DVD_SP_Helper/Commerical/ -
If you use my SVCD to DVD method, you dont need to join the 3 into one mpeg file. The terminal app will join them for you after you have set them to 48khz and remux individually.Originally Posted by EddieRomo
Have you tried demuxing the single .mpeg ifles like you would the joined one?
No, ive played a 3 gig .m2v fine (.m2v by its name doesnt have sound so it will play the movie only)Originally Posted by EddieRomo
try looking at my webpage, and follow the SVCD to DVD tutorial, see what results you get.
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 01:05 -
Demuxing Smartripped VOB with VobEdit06... M2V won't play in VLC?
By Iceblade in forum Video ConversionReplies: 12Last Post: 15th Oct 2007, 23:30 -
Demuxing a "naked" vob to mpeg, m2v, etc
By engineer52 in forum Video ConversionReplies: 2Last Post: 13th May 2007, 16:39
