No matter what ripping program I use I have problems ripping material from DVDs done with a Panasonic E20 and then imported into Pinnacle Impression for reuse.
Basically they import OK, but are shown as being 704 x 576 (being PAL they should be 720 x 576) and when I try to use them Impression freezes.
Does anyone have any suggestions as to what the problem is and what the solution is?
Many Thanks
I just posted elsewhere with this same issue (however, I am NTSC and my problem is 704x 480). I have to reencode the home movie made from my E20 to 720x480 to play in a DVD player. MF2 or sonic MyDVD wont take the files. I think its that darn 704 lines. From other readings it is a valid resolution.
I am doing searches trying to find out what I need to change, but figured I would drop a note here to see if you are anyone has a way to do it.
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 15:40 -
Looking for compact set-top DVD player
By Djinn987 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jun 2010, 15:20 -
setting up dvd / tv / set top box??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th May 2009, 12:48 -
Saw AWESOME HD recorder. No copy protection. HD out. Set top. Real time.
By Evilmind in forum Newbie / General discussionsReplies: 7Last Post: 13th Aug 2008, 18:56 -
Help, unable to rip DVD created from a set top DVD recorder.
By pwangdel in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2007, 18:47
