  1. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    This is probably a dumb question but does anyone know where to obtain updated drivers for your processor? I have an intel P4 2.53GHZ and I didn't know if they even make updated drivers for processors...or where to get them. Any and all information is helpful but I don't see this as a major crisis or something.
    Thanks!
  2. Processors don't have drivers. You may need to update your motherboards bios if using a new chip on an older motherboard. For the latest bios for your motherboard goto the motherboard manufacturers website. You should be carefull what you are doing though when flashing the bios. You should find instructions on the manufacturers website.
