Results 1 to 10 of 10
  1. does anyone know how to make a bin and cue file?
    Aug 2002
    Behind the wheel of a R34
    try WinISO or do a google search
    Mar 2002
    canada
    vcdeasy...
  4. i don't think vcdeasy makes bin and cue files. i'm reading te description and it doesnt say anything about that. were you actually able to do it with vcdeasy?
    Mar 2002
    canada
    oops...your right
    vcd gear will,and its freeware
  6. i know CDRWin is able to make cue bin image files
    nero can burn them but cant create them!
    1)Why Not Overclock a little?! speed 4 free!!!!
    2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website
  7. Hello y'all.
    Why do you want to create .CUE and .BIN files? Is it for making VCD/SVCD or just for writing plain data to a disc?
    I think all of you are partially right about different things. VCDEasy uses the vcdimager package utilities including vcdxbuild to read MPG movie files and create the .CUE/.BIN file pair. So you could use the graphical VCDEasy software to do most of the work for you or you could use the vcdimager or vcdxbuild utilities at the command line (Windows/UNIX).
    Here is an example of vcdimager at the command-line. This will produce two files named VIDEOCD.CUE and VIDEOCD.BIN that you can use to burn a simple VCD.
    vcdimager moviefile.mpg
    I prefer using VCDEasy!
    VCDImager website
    VCDEasy website
  8. tenders i think vcd gear only does it for mpeg1 and mpeg2. i need to do it for an avi file.
    freak_in_cage_10k i know cdrwin does it but i couldnt figure out how to do it with that. do you know how?
  9. Originally Posted by umair
    Why do want to create .bin/.cue files for your purpose? You could create an ISO9660 .ISO image file instead if you just want to put a .AVI file and some other files on a disc, using Roxio Easy CD. Otherwise check out some utilities on CD Media World's website.
    http://www.cdmediaworld.com/hardware/cdrom/cd_utils.shtml
    Please be more specific.
  10. petesimon i just need to make it cause i'm using another software that will lock up what i put on the cd. but in order to do that i need to make a bin and cue file
