Just curious, recently found that my cheap Apex DVD player is capable of playing XSVCD, and I was impressed with the noticeable improvement in quality...my question is, what are people using to encode these things at the higher bitrate? TMPGEnc seems to have a maximum allowable combined bitrate.
I am not sure. I would like to know too.what are people using to encode these things at the higher bitrate?
What bitrate to you want to encode the MPEG-2?
Try Cinemacraft Encoder, TMPGEnc Plus (the best!), Canopus Procoder or whatever else you can find.
CCE website
http://www.cinemacraft.com/eng/home.html
Canopus website
http://www.canopus.com
XSVCD info
https://www.videohelp.com/xvcd.htm -
Did you load the 'unlock.mcf'?TMPGEnc seems to have a maximum allowable combined bitrate.
In TMPG you can make the bitrate whatever you want, if you load the 'unlock.mcf'. Open TMPG and close the Wizard if it opens. Then press the Load button at the bottom right of TMPG. navigate to the Template folder and then the Extra folder in the TMPG directory. Select the unlock.mcf and Load. Now all the "locked" parameters are unlocked. You can set the bitrates for video and audio to whatever suits you.Happy to be here. -
tmpgenc has no max. allowable combined bitrate. you must be referring to the max allowable combined (video+audio) bitrate for standard SVCD, which is 2600 kbit/s. if the combined bitrate is above the standard, then you have yourself a xSVCD. keep in mind, that not that many dvd players support xSVCDs, usually manifests in audio sync problems, jumpiness, blockiness, etc...Originally Posted by njnjr23
in tmpgenc, you can set the bitrate to whatever you want. just keep in mind, higher bitrates means you'll be able to fit less per disc. if you're going to go above max standard (which i approach with my old SVCDs, then you'll fit <40 min / disc) -
[quote="poopyhead"]
But if you use 2-pass VBR then you can use the higher bitrate and still fit more on the disk by keeping the average at say 2000 Kb/s. You should test your player and make sure that it can handle it.Originally Posted by njnjr23"Art is making something out of nothing and selling it." - Frank Zappa -
i'm referring to the avg. bitrate in my statement. of course, you can set the max bitrate to whatever you want, but if the avg. bitrate is only 2000, then you will definitely be able to fit more (but lower quality, regardless of multi-pass VBR). i'm saying if the avg. bitrate were say, closer to 2500, then you'll only be able to fit <40 min/disc.Originally Posted by ZippyP.
Absolutely, the average defines the file size. I'm just suggesting VBR as a means of taking advantage of the higher bitrates (for demanding scenes) while keeping the file size to a minimum. 2-pass does take twice as long to encode, however.Originally Posted by poopyhead"Art is making something out of nothing and selling it." - Frank Zappa
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
