Someone at BestBuy told me that the audio capture is done on the ATI AIW card itself and has nothing to do with the sound card, but the sound on my captures sounds horrible and I want to try and improve it. Will getting a better sound card (I have a Muse now, thinking about getting a sound blaster) make a difference in the final quality of my sound?
Hi,
Whoever told you that is wrong.
I have an ATI AIW 128 Pro and this card is connected to your sound card line-in input. When capturing, sound goes "through" the ATI and is captured by the sound card through this line-in input.
To make a long story short, changing your sound card will have an impact on the captured sound in your videos.
(My personal advice ; stay away from SoundBlaster Live, since it sometimes produces cracks and pops in your captured movies, see many posts on this topic)
Good luck.
Waldok -
Yeah, I 'd got soundblaster, and my captured avi's heard like broken mp3s...
I change it with a Hercules furtissimo, and 2 things happen!
1. The sound get great
2. The CPU suddently used only 60% on full pal capturing. No frame drops at last!
So, yes: Change your sound card. Improves a lot of things! -
My own experience showed me that the sound card makes a huge difference. I got rid of my SB Live as it was giving a real popcorn show in every capture i did and this on both of my computers one in win98 & the other win Me.Changed for a "el cheapo " ess pci card and "voila" no more cracking sound , and no mre dropped frames in high bit rate (+ 2mb/s).So if you have a chance to try a friend's card , give it a try, you might end up with a good result.
Don't ever let other people think for you ,
they will always take the wrong decision...
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
Windows Movie Maker - Why is there no sound after video clips captured?
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Dec 2008, 10:45 -
How to improve the sound quality of this video?
By awaisuk in forum EditingReplies: 2Last Post: 19th Nov 2007, 23:15
