When trying to connect to webpages I know exist I keep getting a dns error. Is there anyway to fix this?
David
Yes, this problem can be fixed, but please be more specific about your situation and state some details too.
Here are some links to webpages that I know work, but I constantly get the dns error on.
http://www.tscv.org/download.htm
http://www.grisoft.com
http://www.divx.com
I have tried hitting the refresh, rebooting, none of these seem to work.
David -
Hmm...interesting. I loaded all three of the web links that you posted here without any problems. I use internet access in a college building with a T1 or similar dedicated connection (Tulsa Community College). The DNS server addresses that your computer uses may be giving you problems for only a few websites--like the DNS server(s) will work with www.yahoo.com but won't work with www.grisoft.com for some unknown reason. Do you have internet access at home?...via standard modem or broadband? Do you use internet access at a office building, college building or similar environment? If you have internet access at home then I suggest you call your ISP technical support line.
Also, you could try the ping command (or similar utility) on the website in question:
Keep trying... -
I only have internet access at home with a dial up modem, my internet access comes from a local college here. Hopefully the tech support there can help me out. How would i do a ping command?
David -
You have XP, correct? To ping:
Go to Start -> All Programs -> Accessories -> Command Prompt
at the prompt, type "ping www. (url here)" as seen in the above post. Obviously, substitute the intended url for "(url here)"
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Issue With D-Link DNS-321 & Seagate 2TB Seagate Barracuda
By RKelly in forum ComputerReplies: 0Last Post: 25th Dec 2010, 22:52 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 16:59 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 11:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
