I've downloaded a SVCD MPG and can't get it to play on my Philips DVD 711. The sound is good, but the image is screwed up. I can see the image, but the screen has a "rolling" or "VHS tracking" sort of effect. I've downloaded the SVCD test file from this site and it works perfectly. The difference between the two files is that my MPG is 480 x 576, 25 FPS (PAL?), and the test MPG is 480 x 480, 29.97 FPS (NTSC?). I'm wondering if my player can't play PAL? If this is correct, can I convert PAL to NTSC? I've tried using TMPGEnc but I keep getting an "file not supported error". I believe I have the right codec. Are there any other packages that will help?
Thanks in advance for any help.
Results 1 to 1 of 1
How do I post a question?
By EricS in forum Newbie / General discussionsReplies: 44Last Post: 22nd Apr 2012, 09:33 -
DVDStyler Quick Question about Pre and Post Commands...
By jubbilee in forum Authoring (DVD)Replies: 1Last Post: 18th Sep 2011, 11:44 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Hi guys...this is my first post here, and I have a question about subtitles
By brian blum in forum Newbie / General discussionsReplies: 7Last Post: 3rd Aug 2008, 09:53
