  1. I've downloaded a SVCD MPG and can't get it to play on my Philips DVD 711. The sound is good, but the image is screwed up. I can see the image, but the screen has a "rolling" or "VHS tracking" sort of effect. I've downloaded the SVCD test file from this site and it works perfectly. The difference between the two files is that my MPG is 480 x 576, 25 FPS (PAL?), and the test MPG is 480 x 480, 29.97 FPS (NTSC?). I'm wondering if my player can't play PAL? If this is correct, can I convert PAL to NTSC? I've tried using TMPGEnc but I keep getting an "file not supported error". I believe I have the right codec. Are there any other packages that will help?
    Thanks in advance for any help.
  2. I figured it out.
