Hey all,
Just used the new update to correct a problem I had creating menu's.. and all worked ok.
However, I didn't test the .ifo's etc.. beforehand, and burn'd them straight to DVD.
When I play the DVD I get a black screen for a menu.
If I press start.. it plays Film 1, or if I press down and start then it plays Film 2. So it works fine... it just doesn't display the "picture".
I'm using Menu 2 and PAL encoding, with the default font.
Any ideas ?
Cheers
If you play on your PC (windvd, powerDVD) does it display?
LuggGuest
I have exactly the same on poweredvd i get a black screen but the buttong are there because the mouse picks them up when i mouse over them, also my VIDEO_TS.IFO file is only 12kb and i would have though it would have been bigger?
On the case chaps - I'll fix it ASAP.
Fixed chaps:
http://www.svcd2dvdmpg.com/SVCD2DVDMPG/Software/svcd2dvdmpg+history.aspx
Go get some!SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Pinncle Studio v12: Menu appearing as blank green screen after render
By jbloggs in forum EditingReplies: 5Last Post: 6th Nov 2009, 21:06 -
blank asset menu
By anakin1312 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 05:21 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
