Hi,
I need to capture directly in MPEG 2 with Pinnacle DC10 Plus. Can anybody help me??
Hi there
To the best of my knowledge, you cannot capture to MPEG with a DC10 Plus. You can only capture to AVI and then convert to MPEG. That may however be dependant on what driver software you are using.
Try the pinnaclesys forum. I know that you will find the answer there.
Hope this helps -
I don't think you can capture direct to mpeg-2 - the DC10+ uses hardware compression, so you can only capture to mjpeg .avi.
that's why I stopped using it and got a different card.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 08:23 -
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
DC10 Plus Capture
By jackylhome in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 18:12 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 23:48
