Hello.
I'm trying to create inserts for the standard size jewel case for my DVD using Nero Cover Designer (V2.2.1.11) and I am trying to do something simple. I'd like a front booklet insert with front title information, and when the sheet of paper is folded it contains content (e.g., track list info) for the front ***inside*** of the jewel case.
I haven't been able to see how to do this in Nero Cover Designer. The program is only offering me Booklet Front, Booklet Rear, and Inlay jewel case insert options, but nothing obvious related to creating content of the inside front of the jewel case insert. Any thoughts on this? If I remember correctly the Roxio EasyCD software did this (i.e., inside front jewel case insert content) with no problems.
When the contents of the Booklet Front and Booklet Rear are printed they are on the same sheet of paper (standard audio document template). When folded, and inserted in the front of the jewel case the content of the "Booklet Rear" needs to be rotated 180 degrees to appear properly as an inside front booklet content. I'm assuming the "Booklet Rear" is literally intended to be used in the rear of the jewel case, which is great but what about content of the ***inside front*** of the jewel case?
Thanks!
--Rob
I am having problems taking off compaq presario front cover. Help
By dymx in forum ComputerReplies: 1Last Post: 24th Jun 2008, 16:42 -
Best paper for cover printing?
By SilverBlade in forum MediaReplies: 31Last Post: 4th Jun 2008, 21:01 -
creating a Booklet??
By wan2no in forum Off topicReplies: 9Last Post: 25th Apr 2008, 19:27 -
Nero Cover Designer
By kenmo in forum MediaReplies: 6Last Post: 25th Jan 2008, 09:43 -
printing DVD cover inserts
By WhiteKenny in forum Off topicReplies: 2Last Post: 8th Aug 2007, 15:56
