i have a problem with encoding godfather 2 2cd
1 cd is oke but the second is f...up , somewhere in the middle
the audio starts to skips( i.i.i.i.ii.a..m.m M.M.M.M.i.c.h.e.a.l c.o.r.l.e.o.n.e example)
If i just take that piece where the audio skips and encode it there is no prblem.
CAn somebody help me pleasee
Does it skip on the mpeg file when played on your PC, or does it only skip once it has been burned to CD. If it only skips on the CD try burning it again at a slower speed.
Did you try re-encoding the whole thing again? It's possible that something happened that tapped into your system resources the first time. Since you can re-encode that one little section with no problem, there's nothing wrong with the source media.
If it were me, I'd just bite the bullet and re-encode the whole shebang again. It sounds like you just had a fluke problem during the first attempt.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
TMPgence xpress 4 can't open rmvb file
By sychern in forum Video ConversionReplies: 0Last Post: 10th Jul 2009, 20:55 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31 -
Working with converting using tmpgence and adobe premiere pro 2.0
By Dante016 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 20:56
