Hi
I have an SVCD movie I want to convert to VCD.
The problem is Cd2 will not even open in Ulead Video Studio or Main Concept Encoder. I get a non responding program.
In TMPGEnc it opens, gets so far in the encoding process then crashes often locking the PC in the process.
Any ideas for any other programs I can try??
The SVCD is non-standard compliance so will not play on my DVD player.
Any ideas??
Cheers
Fozzee
Try ripping the MPEG off the CD with VCDGear. Browse directly to the CD with VCDGear, and set the MPEG to MPEG option (selecting 'fix' isn't a bad idea either). Once you get the MPEG off, you should probably serve it to your encoder using DVD2AVI.
Impossible to see the future is. The Dark Side clouds everything... -
Hi
I only have the mpg files now.
Does that change the advice??
Fozzee -
Not really. You can still run it through VCD gear using the 'fix' option. I've had it fix bad headers, and repair mpeg's to the point where a missing stream would show up. Not sure what it does, but it does work from time to time. Definately try the DVD2AVI, as it seems to work very well for getting video back out of an mpeg. Not as good on the audio, but with a corrupted stream, I think frameserving is probably your best option.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
