Hi,
I am having a problem using Virtualdub to create a .wav file from a DIVX video that I downloaded.
It tells me that the project file size should be 76.5 MB and as Virtualdub processes my file the Audio file size increments until it reaches 76.5MB.
Yet when it reaches this point Virtual Dub does not stop.
It just keeps on processing.
I have to abort the processing.
thanks
I have the same problem when the audio of the divx is mp3. Use VirtualDub-Mp3 that will fix the problem
Yf
Burned Divx movies stopping before end...
By Jeffross1968 in forum DVD RippingReplies: 9Last Post: 18th Feb 2012, 12:08 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44 -
Trimming AVI in virtualdub,direct strem copy ignores my start and end point
By Rudyard in forum EditingReplies: 4Last Post: 4th Oct 2010, 20:11 -
cutting the end of xvid file
By eric123 in forum EditingReplies: 1Last Post: 29th Jan 2009, 15:13 -
Fade End of Video with VirtualDub?
By mlong30 in forum EditingReplies: 5Last Post: 17th Jun 2007, 10:38
