I have used the besliced program before with no problem but this time I opened it up to try to fix my ac3 file and all I get when i select fix file is a notepad. But what differs from all of the other posts about this subject is that my notepad shows all the information besliced gives you when it finishes the fixing of the file. And its of a file I did last month.
I've tried everything. Deleting the program and reunpacking it, but nothing worked.
I use windows xp home and Ive even tried changing the compatibility mode for the programs but nothing changes.
Any advise guys? What gets my goat is that it worked fine for a while a now all this starts!!!![]()
I have the same problem and am not sure why it started doing it.
Now I have to do a lot of transfering of files because my other machine it works on and it is a 800mhz and the one that does not work on is a p4 2.0 gig and they both run win xp pro.
I tried a lot of stuff to try and get it to work but I did not format yet and am not going to just for that program.
good luck if you find out how to fix that let us know
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
