I am trying to convert an avi file captured from my sony dv camcorder and edited in Premiere. I created a .AVS file and ran it with Virtualdub.
I get an error message "Avi source: couldn't locate a decompressor for fourcc dsvd".
I thought Avisynth could open any avi file.
Any idea as to how to fix this sio that I may run my script through avisynth??
Results 1 to 9 of 9
Do you know what type of .AVI file it is? (i.e. DIVX, XVID)
If you don't have the right codec on your machine....no program can open it.
If you don't know what type of .AVI file,
Best bet is to get Gspot
or AVIcodec
Find out what codec you need, install it......problem solved.
Good luck!!
-Nate
Could you include your avisyth script, please. Is your Premiere created avi dv type 1, dv type 2 or something else?
i have the same problem when i try to use avs script using a avi file captured from a miniDV cam via ieee1394
i can open the file im Vdub and in TMpeg directly not from a *.avs script
the DV "codec" that i have in pc is from Pinnacle tried to install Panasonic DV but w/no luck, it donīt appears in the video codec section (XP)
i still try to understand whatīs the problem
2man -
I am capture through premiere from my sony DV camcorder.
The File is avi Type 2.
I am using Premiere DV Microsoft settings.
When I check the codec with avicodec it says sddc or something similar. I need to check at home.
I tried to run the scipt in VirtualDub usind AviSource, OpenDMlSOurce and Avifilesource but non of them work.
The omly way I managed to run the script was by recompressing the file with HUFFYIU codec -
you'll need to get a vfw dv codec. if you goto the tools section on the left-hand side of the page, you will see many different ones. the reason that you can view the dv file currently is because microsoft includes a directshow filter for dv playback in Windows Media Player. Unforunanltly, this filter will not work with vfw based applications (virtualdub, avisynth for example). My personal choise is the mainconcept dv codec
http://www.mainconcept.com/fdl.php?downloads.mainconcept.com+DVCodecDemo2.1+dvdemocodecv2.1.exe -
Did you try directshowsource. Also try capturing type 1 video. Maybe youll have better luck
BTW....this is the last time I try and answer a question at Midnight!
I totally missed things on two posts I had tried to answer....trying to be helpful when I should have been sleeping.
If I would have paid attention I would have seen that you're capturing DV.
Sorry 'bout that!
-Nate
BTW....the mainconcept is the one I've heard mentioned alot.....I hope it works well when I start my DV captures. -
Thanks !
DirectSHowSource did open the file and let me work on it.
Thanks for all the useful input.
vcl file frame serve for avisynth
By norlane in forum Blu-ray RippingReplies: 2Last Post: 5th Feb 2011, 01:20 -
Cannot encode my avisynth file
By V-Spatial in forum Newbie / General discussionsReplies: 6Last Post: 25th Feb 2010, 14:13 -
How to open aac file in avisynth?
By lovyagin in forum Video ConversionReplies: 13Last Post: 16th Aug 2009, 08:25 -
Saving AviSynth script to file
By Leo48 in forum Newbie / General discussionsReplies: 6Last Post: 24th Jun 2008, 14:35 -
Filter just part of a file with AviSynth?
By Holonet in forum EditingReplies: 6Last Post: 2nd Aug 2007, 06:21
