I have been capturing with the following settings.
720x480
avg bitrate 4000kbits/s
max bitrate 8000kbits/s
stereo audio 224
This is with Wintv pvr 250 so the captures are straight to mpg2.
How could I best reduce file size with the least quality sacrifice?
Should I lower avg bitrate?
Should I lower max bitrate?
Will file size be smaller if the max is lower but the avg is the same?
2.5 hours worth of capture(5 tv episodes) with the original settings sometimes fits on one dvd and sometimes does not. So I only need a small tweak to make sure 5 episodes fit on one disc.
Thanks for any help
Slonocode
IMHO you will want to modify the average bitrate. Use one of the bitrate calculators in the TOOLS section to determine what the bitrate should be for your media size and video length.
Also, since you are talking about TV res captures, you might want to consider getting dropping your resolution to 352x480. You will be able to get more time(~4hrs) on the same DVD with a lower bitrate and the quality will not suffer all that much. -
The average is the only one that will affect file size, although all three settings(min,max avg) will affect the quality. Minimum should always be very near to zero, I use 300 so my player doesn't freeze. You can drop your average as low as you like but you should do some testing as quality will be droppping as well. How low you go is personal choice. Like andkiich said, if you drop your resolution you can lower the bitrate considerably. You probably won't notice much loss in quality either, considering your source is a capture played back on a TV.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks for the replies.
I will experiment with the avg bitrate. I only need to save about 300MB per 2.5 hours worth of capture so it shouldn't affect quality very much(I hope).
I don't know if this is true or not but I think I recall reading that captures at HALF D1 resolution can tend to look bad on larger or big screen TV's.
Either way I'm very happy with the quality and as long as I can get 2.5 hours per DVD I feel pretty good about things.
Thanks again
Slonocode -
Originally Posted by slonocode
Then that's really all that matters!"Art is making something out of nothing and selling it." - Frank Zappa
Question about x264's Tuning settings
By CubDukat in forum Video ConversionReplies: 0Last Post: 4th Dec 2011, 23:17 -
WMP settings question
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2011, 15:08 -
XVid codec settings question?
By 3thman in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 16:36 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 17:30
