This pisses me off. What's the point of PowerDVD's Capture feature if it doesn't allow you to capture from DVD-roms!? What program can I do it with? There's a few movies I'd like to capture scenes from.
windvd always worked for me -- i thought powerdvd worked the same way ..
you can also do it in v-dub mod -
Huh? Define DVD-ROM, because if you mean video DVDs played from a DVD-ROM then I think you're mistaken. What other video source would powerDVD have except for video DVDs played on DVD-ROM drives?
What exactly is the problem your having with powerDVD? -
The fuckin capture button is faded out.
I mean a typical DVD movie I pop into my drive, or the ISO of one, etc. -
i just tried it (powerdvd) -- works ok to capture (darn little buttons) , i still like windvd better ...
i capture those stills via moviemaker or power vcr. ive recently been asked by a customer to capture a screen shot in high res so it could be made into a poster. needless to say the cap was way too low res. (320x 240) any ideas how i can get a hi res cap?
Viper, turn off the hardware accelaration in the config under the video tab, then it will work. Also make sure it is saving it to a bmp or it just captures it to the clipboard.
2001-2010 my capture cards - comparison screenshots
By Brad in forum Capturing and VCRReplies: 34Last Post: 15th May 2013, 02:06 -
Best program to create accurate DVD screenshots?
By Killer3737 in forum Newbie / General discussionsReplies: 8Last Post: 15th Feb 2011, 17:39 -
Ati All In Wonder HD and PS3 screenshots and capture HD video.. help needed
By C.P in forum Capturing and VCRReplies: 6Last Post: 30th Mar 2010, 17:46 -
How to make Screenshots of .flv movies ?
By goldtree in forum Video ConversionReplies: 8Last Post: 27th Mar 2009, 10:09 -
How do I capture screenshots of my xbox 360 with a Neoya x2vga?
By travb in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 08:34
