All of a sudden, I'm getting a read error when encoding using TMPG. And, I say all of a sudden because I had it working just a few minutes before doing a test, but after that, I'm now getting a message telling me: Read Error Occurred at address 77F8C4F of module ntdll.dll with 5C0039F8 when I press start. And, to be able to doing anything else with TMPG, I would need to close the program and restart it.
Is there anyone can help me with this problem?
Does this occur with more than one file, and if it does, does the problem persist after you reinstalled TMPGEnc?
Hello. -
I tried another dvd and it worked okay. The problem seems to be when I try to cut the source in half. I ripped only a single vob and was successfully able to encode it, even though I cut the source again. I'm trying to encode the Sopranos.
Are you using the Merge & Cut function, or the Source Range Function. Whichever you are using, try the other function.
Hello. -
I went back and ripped the sopranos a different way and it's working. Thanks for the help.
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 20:20 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
