Hi, i have just applied the latest update and am now unable to encode to ac3 with softencode. It does the stage where it converts to 48k wav with besweet then loads softencode and i get the message "sftencdd.exe has encountered a problem and needs to close" I did not have this problem before applying the update. Any ideas ?
Thanks in advance
AnonymousGuest
Yeah. You're not gonna like this, but it's your crack for SoftEncode.
The "older" crack had that problem when certain features of SE were used extensively.
A "newer" crack will help this problem, but of course I can't officially tell you where to get that, now can I?
If I have assumed incorrectly, and you actually BOUGHT SE, please forgive me... and we'll try to figure it out.
- Gurm
MeGUI - DAR error caused by latest update?
By Tiernan in forum Video ConversionReplies: 0Last Post: 17th Jan 2010, 19:24 -
Display profile causing yellow background, VISTA latest update
By Rudyard in forum ComputerReplies: 3Last Post: 4th Aug 2008, 22:22 -
Um, now what? I'm stuck - SVCD2DVDMPG usage
By Hal05154 in forum Video ConversionReplies: 4Last Post: 13th Aug 2007, 08:59 -
SVCD2DVD won't launch after latest Windows Update of MS .net framework
By starkraving in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Jul 2007, 03:42 -
Win98 update problem
By bevills1 in forum ComputerReplies: 22Last Post: 7th Jun 2007, 14:36
