Can I 'shrink' an ISO file located in my hard disk drive using DVD Shrink ?
By accident I ripped a Layer 2 DVD to my hard disk drive, and now it does not fit into a single DVD+R.
Thanks,
Chucho
you'll need to extract the files from the ISO to process them with DVD Shrink.
I've heard that Daemon Tools can do this - check the Tools section.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
You don not need to extract the image. Daemon tools is a utility that allows you to mount the ISO image files. Mounting the image creates a new drive which acts as if the CD/DVD was in the drive.
I normally only rip ISO image files with DVD Decrypter then mount the image as necessary when I want to work on it. Much faster and easier (vs. several VIDEO_TS folders each with several files) IMHO. -
Chucho, you could also try something like "isobuster" to extract the files.
http://www.smart-projects.net/isobuster/
I do not know if it would neccessitate the use of one of its "freeware" or "shareware" features, or even if it would work, but it might be worth a try. -
ddlooping,
thanks for your input.
I tried "isobuster" and worked like a charm!
thanks again.
Chucho -
That's excellent news, Chucho!
Glad to be of help.
Convert .iso into single Dvdrip
By deepwoodsv in forum Newbie / General discussionsReplies: 15Last Post: 3rd Feb 2011, 14:47 -
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 00:32 -
DL+ burn fails with ISO file larger than 7 Gig. Why?
By anubis13 in forum DVD RippingReplies: 5Last Post: 5th Dec 2009, 18:48 -
how to convert iso to single layer dvd (4.7)
By roboroach in forum MediaReplies: 4Last Post: 1st Dec 2008, 12:44 -
1.3GB DVD Help Camcorder
By Mark V in forum MacReplies: 8Last Post: 18th Sep 2007, 11:24
