I have looked through other posts and see similar problems and lots of different suggestions and answers. I have tried some of them, but I am getting no where fast. I am working on TV Series downloads and most of them are clean, clear and audio/video in sync after DL. But more often than not after I pull the audio into a wav file and then convert in TMPGEnc the audio and video do not match. Sometimes using VDub, I get the message about bitrate, sometimes when I load video file into VDub it goes through a parsing (not spelled correctly) as it loads, other times everything just seems to be going perfect. Yet when I finish encoding sound is off. I have tried same file in Goldwave, same problems. I have tried different settings, and that is a disaster.
In other words I have tried so many different things that now I am totally confused.
If anyone else has had this problem and finally solved it, can you please give me step by step directions that I can understand and apply.
I do not mean to be asking someone to do my work for me, I just need real clarification. Maybe I am trying to do something that is out of my abilities, but I don't think so. What really makes this so frustrating is that I have gotten some that turn out just perfect.
I know that when the DL is not perfect, I am only going to have more problems, but when everything is in sync with the DL, surely there is a way for me to keep it that way.
Mistress Diana
Closed Thread
Results 1 to 1 of 1
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
Video and Audio out of Sync
By Filmmakerx7 in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2012, 06:44 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Video Audio sync help
By carasy in forum Newbie / General discussionsReplies: 10Last Post: 19th Nov 2009, 20:09
