I have Sony's External DRX500ULX DVD burner and can't read the files in each directory on the Mac. I have the Sony on a Windows XP system and used a DVD-R. The Mac is a 17" Power Book with a Super Drive DVD burner running OS X. The file structure on the DVD shows up on the Mac, but each directory is empty. I can copy the same info to a Zip disk or CD ROM with no problem accessing the files. I can put the same DVD disk back in the Sony DRX5000ULX and access it on the Mac through the network and access each file on the Mac with no problem. Something about the DVD when it is in the Mac. Any ideas?
I use both Mac and PC. Mac: G4 Power Book 1GHz w/1GHz ram PC:1GHz w768 both have large SCSI/Fire Wire HD
Capture on Mac - read DV on PC?
By maveni in forum Capturing and VCRReplies: 18Last Post: 5th May 2009, 09:01 -
DV files, read by both Mac and PC ?
By frd1952 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 07:45 -
How to use .M2T files on the Mac
By ArthurDaley in forum MacReplies: 7Last Post: 10th Apr 2008, 03:56 -
opening .z files on a mac?
By jwnulife in forum MacReplies: 1Last Post: 20th Mar 2008, 08:53 -
forget compression, will a Mac G5 Pro/iMovie read an uncompressed AVI?
By nopk in forum MacReplies: 3Last Post: 8th Dec 2007, 23:26
