I have Sony's External DRX500ULX DVD burner and can't read the files in each directory on the Mac. I have the Sony on a Windows XP system and used a DVD-R. The Mac is a 17" Power Book with a Super Drive DVD burner running OS X. The file structure on the DVD shows up on the Mac, but each directory is empty. I can copy the same info to a Zip disk or CD ROM with no problem accessing the files. I can put the same DVD disk back in the Sony DRX5000ULX and access it on the Mac through the network and access each file on the Mac with no problem. Something about the DVD when it is in the Mac. Any ideas?
I use both Mac and PC. Mac: G4 Power Book 1GHz w/1GHz ram PC:1GHz w768 both have large SCSI/Fire Wire HD
What happens if you plug the Sony External DRX500ULX DVD drive to your PowerBook? Can the disk mount with that? If not, try burning in a different format on the XP box, like ISO9660 or something, maybe even UDF (DVD format). See if any of that helps.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I had the same problem .A friend passed me a dvd that i couldn't read.The disc said 4.2gb but it looked empty!
If you want to copy it use Toast .(even though you don't see anything)
It will do the job
Somehow I think it has to do with the way it was burned - which program you used?.
P.S. Check your prefs in Toast and increase the cache and ram to the max(like empty HD space).
Hope this hellps good luck
Can't read disc/ripped VOB files
By koberulz in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2011, 13:34 -
Vivitar HD Files convert to something iMovie can read?
By Quinn82 in forum Video ConversionReplies: 2Last Post: 11th Feb 2010, 23:41 -
DV files, read by both Mac and PC ?
By frd1952 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 07:45 -
How to read my TS files with teletext subtitles in my PC
By foonzoo in forum SubtitleReplies: 3Last Post: 22nd Oct 2007, 13:46 -
DVD with additional files to read on PC
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 01:23
