Ok so now I have switched to yet another DVD authoring program in hopes of gaining sound! Here is the nes scenario.
1. Encoded .avi with TMPGEnc Plus 2.5 using ES stream for video and audio. The results are as expected with me ending up with a .m2v video file and .mp2 audio file. Both of these individual files play fine in their proper players.
2. Used TMPGEnc DVD Author and selected both files as the appropriate source for video and audio. TMPGEnc did as expected and created an AUDIO_TS and VIDEO_TS folder but with one problem. There are no files in the AUDIO_TS folder! Shouldn't there be audio file present?
I'm about to give up on this whole mess!![]()
The AUDIO_TS folder is almost always empty...This has nothing to do with your DVD having sound.
Well believe it or not for some odd reason I copied both of the _ts folders and it finally worked! Thanks for replying anyway. Not sure where the problem was before that's what scares me.
The AUDIO_TS is always empty on movie DVD's. The folder is used for Audio DVD's, which most of us have never seen. The confusion is understandable, because you expect that the sound for your DVD will be in this directory. However the sound is muxed (bundled) with the video in your VOB's in your VIDEO_TS directory.
You should still copy the AUDIO_TS directory to your DVD though, even though it is empty, for compatability purposes. It doesn't always matter, but some players expect it to be there and freak out if it isn't. -
It's also possible that your DVD player does not like mp2 audio. NTSC DVD players only support ac3 and PCM audio. Most will play mp2 audio, but it's not part of the DVD spec (but is in PAL nations).
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
