Well in other words I have these older captures that were done in WMV@ 768kbits (below VCDs 1150Kbits even). Live and learn
Now that I have them I can run them thru TMPGenc and make a 352 by 240 by 48Khz audio and burn to DVD. However the results are so-so.
What software should I use (Vdub Mpeg? or Tmpgenc) and what filters to improve the visual results. I'm looking for something without frameserving since for some reason I can't seem to get the process thru my thick skull.
The problem is some look decent except high motion and others just look fuzzy all the way thru, and no I can't go recapture them, Dang-it.
I burned a test DVD and some of them seem to have a fuzzy effect around figures in motion. I wish I could re-cap with my Canopus ADVC now, but gone is gone. Live and learn. Damm cheap $20 capture card!
Some things I'm not going to bother trying to fix as I have the S-VHS camcorder & Tape and can do a do-over thru the Canopus. Others were from other family members and are gone to who knows where.
So any thoughts?
I'd try frameserving if anyone knows where to get a framserving guide for dummies tutorial. But even then I prefer the one step at a time approach. IE set up TMPGenc and run it's batch process while I sleep.
Roger
Your probably wasting your time. Simply resizing them to a higher resolution, or changing the type of file from WMV, to MPEG gains you nothing (you actually lose even more quality).
The problems your describing are compression artifacts. They are probably embedded in your source video. Put there when it was created using a low bitrate, and carried over to anything you create from your source as a result. You can try to filter them out, but given the poor quality of your source to begin with, I'd say that was also a waste of time. If you want to try anyway, you can try a temporal smoother in VirtualDub to remove the mesquito noise around objects.Impossible to see the future is. The Dark Side clouds everything...
Need urgent help to improve quality of mp3 files?
By apple4red in forum RestorationReplies: 2Last Post: 10th Oct 2010, 17:45 -
Improve Quality of Downloaded FLV files..
By Deter in forum EditingReplies: 4Last Post: 9th Jul 2010, 22:25 -
file format for storing video files (wmv or h.264)
By the_shyguy in forum Video ConversionReplies: 24Last Post: 10th May 2010, 02:21 -
Unable to convert some WMV files to Ipod Touch format - Why?
By tradertt in forum Video ConversionReplies: 14Last Post: 8th Oct 2009, 05:22 -
how do I join 30 .wmv files together before converting to DVD format
By dvdnewbie64 in forum EditingReplies: 3Last Post: 14th Dec 2008, 23:58
