I'm trying to create a xvcd, so I can fit a 90min video in an 80min cd-r.
To make the video file smaller, I changed the bitrate to 950kbps and the framerate to 23,96fps (NTSC). As 950/23,96 > 1150/29,97 there shouldn't be any real loss on video quality. The problem is when I try to encode it with TMPGEnc. I always change that option on settings to VCD Non-Standard, but in the end the filesize is the same of a VCD Standard.
The video is in divx, so if I convert it to VCD Standard, the mpeg file size is 872Mb, so it won't fit in an 80min cd-r. Reducing the bitrate and framerate, as a Non-Standard VCD, the filesize should be something around 750Mb, but in the end all I get is a video with 950kbps and filesize=872Mb. =/
What am I doing wrong?
Have you tried to use the wizard to take care of the other settings?
Hello. -
No, I never let wizard take care of the video settings. I always configure everything by myself because I like to create chapters in all my vcds and my standalone plays vcds in 16:9 NTSC. Since almost all the videos you can download are 1:1 VGA, 4:3 PAL or 4:3 NTSC, I always convert the files before burning. So, I just don't let wizards take care of my stuff. =)
More details:
I encoded audio and video separated... So now I have a 140Mb audio file and a 594Mb video file... 140+594=734Mb...
Then I try to just multiplex it... And the result is... A 871Mb file! =////
I tried Multiplex and Simple Multiplex... Always in VCD Non-Standard...
Can anyone please tell me what the hell is wrong?
Thanks! Hehehehe
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
Does anyone have a preset for 1:1 encoding ratio with tmpgenc plus ?
By LordVader in forum Video ConversionReplies: 3Last Post: 9th Dec 2009, 09:21 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
