Hi all, my buddy just gave me his Toshiba SD-2700 to replace the older toshiba that I currently have. But the problem is that whenever I try to play any DVD's (retail, haven't tried and burned ones) I keep getting a "woop" and "pop" sounds during playback. It's quite loud, louder than the actual movie level.
My setup is quite simple, I have RCA's going into a Sony mini-system for the sound. It works perfectly with the older toshiba DVD player (sd-1200 I believe) but just not with the "newer" player.
My buddy thinks it's because I'm going through a mini-system. It worked fine on his system (full surround sound system, HDTV, etc.)
I have "Analoge 2 CH" selected in the setup menu, other than that, I'm clueless.
Thanks!
Results 1 to 1 of 1
END OF LINE
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
My Samsung HT-TZ315 with Divx playback and "USB host" Blew up!
By BaggyB in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Jun 2009, 06:28 -
LG LDA-531 Playback Issues "No Memory Card Present"
By philrivoire in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Mar 2008, 11:44 -
Sudden "Playback prohibited by area limitations." problem
By ph1losophe in forum Authoring (DVD)Replies: 11Last Post: 16th Jul 2007, 23:46
