Hello! I have finished my first project on S8 and it is 55 minutes long. I am ready to burn to DVD. I started the "make disc" process to burn directly to disc but it is still not finished rendering...I started at 4:30 am and it is now 9:50am...5 hrs and 20 mins...is that normal to render 55 mins? I have a P4 2.4 Ghz w/ 512 ram and dedicated hard drive for capturing. What is proper procedure? Do I create image first and then burn later (is this faster)? Is this normal for S8 to take this long? Please advise. What are alternatives to burning after I finish a project on S8?
Thanks in advance.![]()
Thanks and regards,
RayBan
ATI 9600 Pro; Abit BH7; P4 2.4Ghz 533; 1G PC2700 DDR; Toshiba SD5002 DVDR; WD 120G 8MB 7200 Capture Drive & 160G 7200 Program Drive; Pinnacle Studio 9 and Nero6 -
It has to render/encode, then compile, then burn in that order.
I suggest you see the Pinnacle Studio 8 webboard.
ffmpegX taking LONG time
By macgurl in forum ffmpegX general discussionReplies: 1Last Post: 23rd Apr 2011, 00:50 -
Editing video in virtualdub taking so long!
By admirer in forum Newbie / General discussionsReplies: 14Last Post: 8th Apr 2010, 13:43 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 09:39 -
Rendering taking too long- How to speed it up? (Sony Vegus movie)
By Entry in forum Newbie / General discussionsReplies: 9Last Post: 18th Aug 2009, 00:47 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 14:29
